This discussion topic has been answered Discussion topic: Sky Q box showing “no satellite signal” for BBC 1/2 but other channels working
Message posted on 03 Oct 2023 08:24 PM
For past month I've had BBC 1/2 showing "No Satellite Signal" and now it's started to affect ITV 1/2 also. I watch a lot of Netflix but I don't wish to loose the main terrestrial channels.
if I go to "Settings"-> "Status"->"satellite signal" it shows a tick. "More Info" shows:
Signal Locked
signal Strength 40
Signsl Quality 90
LNB type Wideband
dish isn't shared, it hasn't been moved, not obstructed
I've restarted the Q Box, Powered everything down and restarted, still no joy.
Any ideas?
TIA
Message posted on 03 Oct 2023 09:22 PM
Thank you! I have booked an engineer!
Message posted on 03 Oct 2023 08:26 PM
Re: Sky Q box showing “no satellite signal” for BBC 1/2 but other channels working
@Scanweb
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
Message posted on 04 Oct 2023 08:00 AM
I've got same issue for bbc 101 but can watch other area bbc on channels 955 etc
Message posted on 04 Oct 2023 08:08 AM
The advice is the same. It sounds like your dish alignment needs checking.
