Discussion topic: Sky Q box regulary loses internet connection.
Re: Sky Q box regulary loses internet connection.
@mart6391 wrote:
Had this problem over and over then when I was on box #4 the engineer stated the SkyQ Box has a **bleep** antennae - the signal is extremely weak - typical penny junk. I had a Repeater close by and she hooked up an ethernet cable from the back of the Sky Box to the Repeater. That was over 3 years ago and since then no dropped connections.
The antennae problem will not be sorted as Sky has dropped any development on the SkyQ Box. Their scripted solution is to use Sky Broadband which is false. The problem is within the SkyQ Box itself and that cheap antennae.
This is basically what I do, more or less.
It's antenna by the way - antennae is the plural 😉
This message was authored by: SkydontlikeEE
Our box won't let us do it!
This message was authored by: BazzerUK
What won't it let you do? I have connected a cable from an extender which has sorted the problem
brh
