Discussion topic: Sky Q box regulary loses internet connection.
Message posted on 16 Mar 2025 10:35 PM - last edited: 16 Mar 2025 10:36 PM
Re: Sky Q box regulary loses internet connection.
That happens a lot 😄
Yeah my opinion is the only solid fix is to not use wifi.
or get a Q booster, hardwired into the router. That seems to work for a lot of people.
Message posted on 18 Mar 2025 08:50 AM
I bought cables as suggested and still getting blackouts. Q is, could the fact the signal goes via the soundbar be a key factor to resolving this? Seems like i have to chose between video/audio quality or replace bar?
Its a samsung k950, Atmos is only available thru hdmi, so seems i cannot use optical for audio, hdmi for video.
As always any suggestions welcome!
Message posted on 18 Mar 2025 09:04 AM
Have you tested not going through the soundbar to isolate the problem?
Message posted on 18 Mar 2025 09:07 AM
Not as yet, if this idea has mileage I will do.
Message posted on 19 Mar 2025 07:36 AM
Performed this check and all seemed ok removing soundbar from system. Now need to figure out if the item I read online about HDR pass thru is correct for my Samsung K950. It could be time to replace...
Message posted on 19 Mar 2025 08:16 AM
Could you just hang the soundbar off the ARC HDMI port?
Message posted on 19 Mar 2025 08:33 AM
As I understand it, the sky box needs to be in one of the Sound bar HDMI's for atmos to work...but I can try it...
Message posted on 19 Mar 2025 08:38 AM - last edited: 19 Mar 2025 08:42 AM
@Mattcarpenter82 wrote:As I understand it, the sky box needs to be in one of the Sound bar HDMI's for atmos to work...but I can try it...
Likely but Atmos on a soundbar is kind of nonsense anyway.
if the TV allows passthrough of the audio bitstream and has an eARC port (and the soundbar supports it too) I think Atmos might still make it through.
Message posted on 19 Mar 2025 08:55 AM
Thanks, I'll give this a go tonight if time allows.
Message posted on 19 Mar 2025 09:54 PM
Currently on test with all devices now feeding into tv and then soundbar on eARC to TV.
Why do u say Atmos on Soundbar is nonsense?
Message posted on 19 Mar 2025 10:20 PM
Atmos really needs proper surround speakers to do it justice.
Having said that, I haven't even bothered with rears since we moved house 9 years ago. 😁
Message posted on 20 Mar 2025 08:52 AM
Oh i see. My K950 has wireless rear surrounds 👍
Message posted on 13 Apr 2025 08:58 AM
Mine does the same occasionally. I'm with BT . Nothing todo with BT broadband. . It's the crap sky q box. Mine loses connection and picks a sky broadband . I have to reset broadband connection. Sky box is crap
Message posted on 22 Apr 2025 02:41 PM
I am having the same problem nearly every day so frustrated with sky. It seems a widespread issue but not bothered to sort it.
Message posted on 27 May 2025 08:40 AM
I have same problem and have sky broadband
