Discussion topic: Sky Q box regulary loses internet connection.
Message posted on 21 Jan 2025 02:12 PM
Re: Sky Q box regulary loses internet connection.
I'd be interested to know more details of your set up
Message posted on 21 Jan 2025 02:28 PM
A simple set up really.
Vodafone Router - Sky Q box - 2 x Mini Boxes - 2 x Booster.
Initially engineer stated the router was directly linked to one of the mini boxes, which linked tio the other, which then connected to the Sky Q box. He installed the booster, changed the setting to 2.4ghz and reconfigured them so that the Router connected to the Sky Q box which connected mto the booster, which connected to a mini box and then to the other mini box.
Message posted on 21 Jan 2025 02:43 PM
This 2.4ghz thing seems to be significant. Since i changed my setup and all sky products only connect to 2.4ghz we have had no disconnects for approx 2 months.
Everything else in the house connects to either 2.4 or 5ghz without issue, including smart tv's.
We also connect to netflix etc via smart tv and not skyapp, the skyapp buffered constantly.
Message posted on 21 Jan 2025 02:59 PM
I found i could strip out half the kit sky put in. Are you having issues currently?
Message posted on 21 Jan 2025 03:09 PM
No issues now. Only sky kit we have is the main skyq box and a mini.
Fibre is provided by YOUFIBRE now and is spot on. (previously Virgin)
Message posted on 21 Jan 2025 04:08 PM
Sorry was meant for Rich
Message posted on 21 Jan 2025 04:09 PM
Yes - but not every day. Every few days I have to turn my router off and on again because Sky is not connected to the internet, even though everything else in the house is connected just fine.
Message posted on 21 Jan 2025 04:40 PM
So, I have both 2.4 & 5 on.
Whats your dns set on the main q box?
What kind of distances are you operating at?
Have u tried no minis, then 1 mini, then perhaps 2 (switch off at mains).
Are your standby modes all set to the same, active.
Software updates correct on all boxes?
Any other equipment in house, ie range extenders etc
Message posted on 21 Jan 2025 04:50 PM
I'll go through and check all of your suggestions as soon as I get chance - thank you
Message posted on 21 Jan 2025 04:53 PM
Where do I find the DNS?
Message posted on 21 Jan 2025 05:03 PM
Whats your dns set on the main q box? Not sure where to find this??
What kind of distances are you operating at? Router is in the office and Sky Q in livivng room - about 6 meters away.
Have u tried no minis, then 1 mini, then perhaps 2 (switch off at mains). - Not yet tried this.
Are your standby modes all set to the same, active. - They were all on Eco but changed them to Active.
Software updates correct on all boxes? - Yes - I beieve all are latest version.
Any other equipment in house, ie range extenders etc - Got a booster directly above Sky Q box (upstairs) to help with Mini-boxes
Message posted on 21 Jan 2025 05:16 PM
Manual network settings/advanced.
Message posted on 21 Jan 2025 05:18 PM
A Sky booster or alternative? What distances are minis from wifi, and minis from main q?
Message posted on 21 Jan 2025 11:54 PM
With cabling directly completely impractical for my situation, what alternative to wi-fi is there? Everything else that uses my wi-fi is 100% reliable so why is Sky so poor? It really is not good enough, and Sky are very cavalier about it. My system had been stable for a couple of weeks but has started playing up again. The money spent by users is very significant and system stability should be rock-solid.
Message posted on 22 Jan 2025 05:44 AM - last edited: 22 Jan 2025 05:47 AM
Powerlines or a wifi mesh with the sky boxes hard wired into nodes.
yeah it's not good enough but there's no point whinging, it's not going to change. You either work around it or leave.
