Discussion topic: Sky Q box recording light permanently lit, but no programme being recorded.
Message posted on 31 Aug 2023 04:27 PM
Sky Q box record light permanently on but no programme being recorded. Box has been reset but issue remains. Programmes can still be recorded and downloaded
Message posted on 31 Aug 2023 04:30 PM
Re: Sky Q box recording light permanently lit, but no programme being recorded.
Hi @John3822
Did you try a Reset Settings in the Q box hidden menu.
