Discussion topic: Sky Q box planner is all over the place and not grouped and EPG has missing programmes.
Message posted on
19 Jun 2025
06:29 PM
- last edited:
20 Jun 2025
09:48 AM
by
SpaceSparkie
- Seems that programs are all over the place on my planner. They never used to be. I've tried unplugging and repluggibg in. Nothing seems to change them. I'm quite annoyed with Sky as they make it so hard to speak to a human and the automated voice thing is [removed] and eventually cuts you off.
I need this problem sorting so that all my programmes I've recorded are grouped back together.
the other thing I notice is programmes missing from the EPG. I need to get them back.
Moderator Actions: removed inappropriate language
Message posted on 19 Jun 2025 06:39 PM
Re: Sky Q box planner is all over the place and not grouped and EPG has missing programmes.
I know you said you've unplugged etc but try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 19 Jun 2025 09:38 PM
Thanks for your advice. I went through all this as you described. I'd made no difference.
