4
This discussion topic has been answered Discussion topic: Sky Q box, orange light on standby, but works
This message was authored by: Foxhole
Hi all,
I had Sky Q installed yesterday (Sky broadband last week), I noticed that the light goes orange when on standby but turns on (goes green) and seems to work fine, is this normal? I thought the light should go red when in standby.
I've seen a lot of posts about the light being orange and not turning on or suggesting there is a problem with the equipment, so just a bit concerned.
Any help is appreciated.
Thanks.
This message was authored by: Chodley Answer
Re: Sky Q box, orange light on standby, but works
orange is normal in standby.
Avatar for Foxhole
Thanks for confirming. When I got up this morning it had gone red, I assume it goes into a deeper power saving mode or something?
Yeah between 2:45 and 5ish usually.
Avatar for Foxhole
Brilliant, thank you
Answered - Go to Answer
