Discussion topic: Sky Q box not turning on
Message posted on
13 Nov 2024
04:18 PM
- last edited:
14 Nov 2024
10:04 AM
by
Kelsingra
I got my broadband speed upgraded yesterday a.d mi sky Q mini box not working get to when screen goes blank press the home button then screen goes blue and then is stayed blue and box doesn't turn on
Moderator note: Changed title to reflect topic more.
Message posted on 13 Nov 2024 04:38 PM
Re: .iss c s.ith
Hi @Cathie2
Reboot the mini as above.
