2
This discussion topic has been answered Discussion topic: Sky Q box not switching on
This message was authored by: LittleMum24
My SkyQ main box will not switch on with the remote. The mini box is working and I have checked all the wires at the back are connected. I have changes the batteries in the remote. Still not switching on. Any suggestions?
This message was authored by: Laing1 Answer
Re: Sky Q box not switching on
@LittleMum24 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
then
Avatar for LittleMum24
Level 0 icon
Hi @Laing1
Followed the instructions to reboot the SkyQ box and success. Thanks
Answered - Go to Answer
