Discussion topic: Sky Q box not connecting to wifi
This message was authored by: Caro1903
Have live tv channels but unable to access apps. Have tried all suggestions on line
Re: Sky Q box not connecting to wifi
@Caro1903 have you tried resetting your router by pressing and holding in the reset button on the router
then
 rebooting your main Q box ie
switch it back on then follow the on screen instructions your Sky Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
