Discussion topic: Sky Q box not connecting to the internet
This message was authored by: Songmanbob
My Sky Q box is not connecting to the internet. It's connected to the router but not connecting to the internet. My phone, laptop, iPad, home security cameras and Google Home are all connected to the internet fine, just not the Sky Q box.
I've done a power-down reboot but no change.
Re: Sky Q box not connecting to the internet
Hi @Songmanbob
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
This message was authored by: NeilSmith81
I'm currently having the same problem. Unable to connect to internet and it is preventing my mini boxes from connecting also.
This message was authored by: Basavaki
I'm having the same problem.  Initially after reseting i get a connection to both the router and the internet but after a few seconds the internet drops off.  I've tried this with a wired connection and through wifi and get the same problem.  Looking through the discussion forums, people were reporting very similar sounding issues in January and in March both of which were resolved by Sky, but I don't see any details on what they did.
