Discussion topic: Sky Q box not connecting to router
Message posted on 09 Oct 2023 08:40 PM
Sky Q box not connecting to router. No network connection message. Unable to use apps or on demand. Tried all the tips. Restarted both bits of equipment and reset. Help!!!
Message posted on 09 Oct 2023 08:43 PM
Re: Sky Q box not connecting to router
Hi @kaznjohn
Assume this is your Main Q box.
Have you carried out a Network reset exactly as follows.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 13 Oct 2023 01:45 PM
Hi oldfella, thanks for answering my query. This is my main Sky Q box and I have reset it. It keeps telling me to press WPS button on router to connect but this does not work. I think I'm going to have to phone Sky as I have tried everything they suggest.
