Discussion topic: Sky Q box not connecting to internet
Message posted on
06 Aug 2024
06:51 PM
- last edited:
07 Aug 2024
10:21 AM
by
Daniel-F
The sky box is saying it looks like you so not have Internet connection right now I've reset the box we have Internet connection on our phones from the box but the sky box doesn't
Moderator note: Amended title to better reflect query
Message posted on 06 Aug 2024 06:53 PM
Re: Internet
@Samuel4 Which Sky box do you have? Sky+HD, Sky Q or Sky stream?
Message posted on 06 Aug 2024 06:55 PM
Re: Internet
Sky q box
Message posted on 06 Aug 2024 07:45 PM
Re: Internet
Hi @Samuel4
