Discussion topic: Sky Q box not connecting to internet
Message posted on 02 Aug 2024 01:53 PM
Sky Q box not connecting to internet. Sky channels work fine. Other devices (mobile etc) are all on the internet and working. I have followed all steps to reboot box, tv and router to no avail. I tried to ring sky - chat bot checked service which was working and then gave no further help.
Twice in the last month I have had to contact Sky and both have been unsuccessful even for none related queries
Message posted on 02 Aug 2024 05:51 PM
Re: Sky Q box not connecting to internet
Hi @Sammiejoe3
Message posted on 04 Aug 2024 08:29 AM
I have done all that still
not connecting
Message posted on 05 Aug 2024 10:17 AM
I am now unable to work no devices will connect to the internet. I need help from an engineer asap
