Discussion topic: Sky Q box not connecting to internet.
Message posted on 06 Jun 2023 11:18 PM
My sky q box, that was working fine, will now not connect to the internet. I have read several other posts on this subject and tryed all the tricks and tips listed therein, all to no avail.
Message posted on 07 Jun 2023 09:52 AM
Re: Sky Q box not connecting to internet.
Same for me. Was working fine couple of days ago. Tried all the recommended "fixes" multiple times but still no joy. Internet is working fine on all other devices.
Message posted on 07 Jun 2023 09:55 AM
Hi @Corrode+Alloy Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 07 Jun 2023 09:58 PM
Hi Quoman, Yes I have tryed all that several times and a few other things too. It's now telling me I have no satelite signal! Well there wouldn't be as there is no satelite dish.
Message posted on 08 Jun 2023 08:50 AM
@Corrode+Alloy have you recently moved into a property with no satellite dish or had it taken down for building works as Sky Q needs a satellite dish to work.
Message posted on 08 Jun 2023 06:18 PM
@Laing1 Having checked my dish, I find I have the finest dish in the realm but I'm not interested in the dish at all. The only thing I'm concerned about is connecting my q box to the internet as it was in times past, not very long ago. It is this that I'm having a little trouble with and am indevering to rectifiy.
Message posted on 08 Jun 2023 06:39 PM
@Corrode+Alloy I'm confused as you said in a reply to @Quoman7 It's now telling me I have no satelite signal! Well there wouldn't be as there is no satelite dish as per the quote above, but now you are saying you do have a dish ???
Message posted on 08 Jun 2023 08:41 PM
@Laing1 Sorry about that. I confuse myself sometimes. The dish is there and working great but I keep getting this everytime I try to connect to the internet.
This has been the case for the last few days, before that everything worked fine.
Message posted on 08 Jun 2023 09:25 PM
@Corrode+Alloy no worrys
so who is your broadband provider is it Sky or a third party ?
Message posted on 08 Jun 2023 09:38 PM
@Laing1 Sky provides our broadband. Our router has model number SR203 and looks like this:
Message posted on 09 Jun 2023 04:26 PM
@Corrode+Alloy yeah I have that router
so have you tried doing a network reset on the main Q box ie go into settings > setup > network then scroll across to reset I am guessing you probably have already tried that
I have noticed when I've reset the network that it can take 3 or 4 attempts with wps before the router connects to the box
Message posted on 10 Jun 2023 09:59 PM
@Laing1 Yes I've done that reset and then tried several times to connect to the Internet. The ratio of joy to misery regarding television makes me question whether it's worth the trouble.
Message posted on 11 Jun 2023 10:54 AM
@Corrode+Alloy I can escalate this to Sky for you where they may contact you on a chat window through the forums. It's not instantainious chat but it may help ? it may be today or moe possibly tomorrow that Sky may pick it up ?
Message posted on 11 Jun 2023 09:35 PM
@Laing1 Thank you. That sounds like a plan. Let's give that a go.
Message posted on 11 Jun 2023 09:41 PM
@Corrode+Alloy I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
