Discussion topic: Sky Q box not connecting to broadband
This message was authored by: SAM0771
Sky q not connecting to the broadband
Re: Sky Q box not connecting to broadband
Hi @SAM0771
Have you carried out a Network reset on the main Q box exactly as follows:-
Avatar for SAM0771
Thank you got it sorted for now and a new box coming out this week
