Discussion topic: Sky Q box not connecting to WiFi
This message was authored by: VickieRick
Sky Q Box no longer connecting to WiFi. WiFi service is good and working perfectly for all other items around house.  Not able to resolve via network settings.
Re: Sky Q box not connecting to WiFi
Assume this is your Main Q box @VickieRick
First reboot your router.   Disconnect power lead for 30 secs and then reconnect.
Wait until the router is completely back up and running and then carry out a Network reset on your Q box.
