Discussion topic: Sky Q box male connector broken
Message posted on 16 Aug 2023 02:57 PM
Message posted on 16 Aug 2023 03:09 PM - last edited: 16 Aug 2023 03:09 PM
Re: Sky Q box male connector broken
@StephenB76 It's a F-connector either screw on or crimp on, screw on would be best.
Message posted on 16 Aug 2023 03:15 PM
@GD1 Thanks for the quick response👍 . Do these come in different sizes or are they just standard and will fit my Sky cable?
Message posted on 16 Aug 2023 03:16 PM
@StephenB76 All are standard size.
Message posted on 16 Aug 2023 04:02 PM
@StephenB76 wrote:...Do these come in different sizes or are they just standard and will fit my Sky cable?
When the length of coaxial cable is below around 45 metres Sky will have used a thin CT63 / WF65 specification cable, for coaxial cable lengths between 45 metres and 75 metres then Sky will have used a thicker CT100 / WF100 specification.
So, you will probably require an F type screw on connector suitable for CT63 / WF65 coaxial cable.
Message posted on 16 Aug 2023 06:32 PM
@StephenB76 wrote:
One of the 2 male connectors that screw into the back of my Sky Q box is broken. The thin piece of copper has snapped and is causing my picture to be pixilated. Can I replace this connector, and if so what type of connector do I need to buy? TIA
The below link might be of some use for refitting the satellite connector...
How to fit/replace an F type coaxial connector for Sky TV cables
Sky Q 1TB UHD
LG TV
Sky Mobile
