Discussion topic: Sky Q box makes whirring noise and has to be rebooted every day - 2nd time it’s happened.
Message posted on 10 Nov 2025 07:39 PM
My Q box keeps failing to start, making loud whirring noise. Is fixed by pulling orange plug and leaving for a few minutes - nuisance as is now doing it daily.
Not on carpet or near radiator. 2nd time it's happened. Previous box replaced.
Message posted on 10 Nov 2025 08:06 PM
Re: Sky Q box makes whirring noise and has to be rebooted every day - 2nd time it’s happened.
Assume you are not switching the Q box off at the wall and it is normally in Standby.
