Discussion topic: Sky Q box makes a noisy whirring. Has intermittent connection to WiFi and I often have to reset it.
Message posted on 29 Dec 2023 12:29 PM
My Sky Q box has been making loud whirring noises, but also drops its connection with the WiFi and I often have to turn the box off and on to get it working
Message posted on 29 Dec 2023 12:32 PM
Re: Sky Q box makes a noisy whirring. Has intermittent connection to WiFi and I often have to reset
Hi @KatDawson
Message posted on 29 Dec 2023 12:47 PM
Thanks, just done this hopefully it sorts out the problem 🤞🏼
Message posted on 31 Dec 2023 09:24 AM
@oldfella unfortunately didn't work. Will need to try and contact Sky I think! Feel like the box is going to give up at any moment!! Thanks for your help
Message posted on 22 Sep 2025 09:51 PM
Hi
did you resolve this issue. We are on our 6th box. So what else could it be. It's so frustrating
many thanks
