Discussion topic: Sky Q box looses connection and wont turn on till we pull the power and rest the box. This has been
Message posted on 15 Jul 2023 10:57 AM
Our sky Q box won't turn on and connect.
We have to pull the power on the box and reset to get this to work.
We're now having to do this atleast 3 times a week.
Message posted on 15 Jul 2023 11:01 AM
Re: Sky Q box looses connection and wont turn on till we pull the power and rest the box. This has b
To change your standby settings:
Press Home on your Sky Q remote and select Settings > Setup > Preferences > Standby mode, and select the setting you want. I personally have all my boxes set to NONE.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 15 Jul 2023 11:05 AM
Hi Thank you for your response .
I have already changed these settings and it has made no difference.
The Box will also randomly just turn off and not turn back on again!
