Discussion topic: Sky Q box locking up, will not turn on or respond, withfan running continuously.
Message posted on 21 Jan 2024 12:13 PM
This problem started about a month ago.
Since then I have had 2 "new" sky q boxes, last one via technician visit.
Most mornings I try to access the mini box to find no signal error. The main box is frozen, will not switch on, & the fan is running constantly. This went on for 4 hours, as tried to see if it fixed itself.
Original setup.
Sky q box to sony soundboard, then tv.
Changed to remove soundboard, & changed hdmi cable to new sky item. Connected directly to full fibre EE modem.
Temperature at box monitored & did not exceed 21C. Will try disconnecting tv this evening, & tomorrow cat 6 cable.
Any suggestions welcome.
Message posted on 21 Jan 2024 01:11 PM
Re: Sky Q box locking up, will not turn on or respond, withfan running continuously.
Original setup.
@rogc1 have you tried changing the standby settings on your box from eco to none see lin k below
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
