2
This discussion topic has been answered Discussion topic: Sky Q box keeps crashing plus can’t connect to Netflix
This message was authored by: JD2024
We can be watching tv through Sky when screen will go black and reverts to free view on TV.
We've also lost connection to Netflix. Just get the loading circle
Avatar for JD2024
This message was authored by: JD2024 Answer
Re: Sky Q box keeps crashing plus can’t connect to Netflix
Thank you. Both issues now resolved following your advice.
Hi @JD2024
Regarding your Netflix issue see the following thread
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
For your Q box issues
Try a Reset Settings in the main Q box hidden menu.
Avatar for JD2024
