Discussion topic: Sky Q box isn't working
Message posted on 28 May 2024 02:26 PM
There is a blue flashing light with the red standby on the box. I've tried rebooting it about 4 times but still nothing
Message posted on 28 May 2024 04:07 PM
Re: Sky Q box isn't working
Hi @Hunter24
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
