Discussion topic: Sky Q box isn’t connecting to virtual remote and main physical remote won’t work
This message was authored by: Jake23
My sky Q main box remote won't work and the box won't connect to virtual remote has anyone had this problem
Re: Sky Q box isn’t connecting to virtual remote and main physical remote won’t work
@Jake23 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
or
connecting the virtual remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
