Discussion topic: Sky Q box isn't broadcasting wifi
This message was authored by: df46
I have a Sky Q box in one bedroom and the router in the next bedroom. I can see and connect to the sky wifi while in the room with the router but this drops as soon as I go into the bedroom with the Sky Q box. I have checked the Sky Q settings and wifi appears to be turned on - but there still isn't a signal in that room. What else can I do ?
Re: Sky Q box isn't broadcasting wifi
@df46
Do you get your broadband from Sky?
If not, the hotspot functionality has to be manually activated.
@df46
https://www.sky.com/help/articles/wifi-hotspots
