Discussion topic: Sky Q box is very slow to change channel and keeps freezing. I have reset it three times but still n
Message posted on 19 Oct 2024 02:33 PM
Sky Q box is very slow and keeps freezing. Have reset it 3 times but still not very good. Is this a wider problem?
Message posted on 19 Oct 2024 03:37 PM - last edited: 19 Oct 2024 03:37 PM
							Re: Sky Q box is very slow to change channel and keeps freezing. I have reset it three times but sti
Have you carried out a Reset settings in the hidden menu @AW06 ?
