3
This discussion topic has been answered Discussion topic: Sky Q box is stuck the blue menu after I tried to put volume on the remote.con
This message was authored by: 1234+weekender
Was trying to put the volume control of my Sky Q on my remote ,I pressed 1 & 3 buttons and now my Q box is stuck on the blue menu page and I can't change it .
This message was authored by: MightyQuinn Answer
Re: Sky Q box is stuck the blue menu after I tried to put volume on the remote.con
Hi @1234+weekender   I would reset the remote to IR mode (line of sight) by holding down 7 & 9 until the led flashes 4 times. If necessary, power reboot the Sky Q box.
Avatar for 1234+weekender
Hi Mighty Quinn,
Problem solved thanks for the help.
Thanks for your help Mighty Quinn problem solved
Answered - Go to Answer
