2
This discussion topic has been answered Discussion topic: Sky Q box is connected to internet and this is confirmed in settings. However Home says no internet
This message was authored by: SkyHighGuy
home Vodafone internet working fine and sky Q box settings say connected to router AND internet. But other screens saying no internet connection - Home, Catch Up etc. any suggestions?
Avatar for SkyHighGuy
This message was authored by: SkyHighGuy Answer
Re: Sky Q box is connected to internet and this is confirmed in settings. However Home says no inter
Tried resets to router and Sky Q box but didn't work. Called Sky & did software download to Sky Q box (wi-fi worked for this!) and now back up & running with good wi-fi connection.
Hi @SkyHighGuy
Try reconnecting your main Q box.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
