6
This discussion topic has been answered Discussion topic: Sky Q box has suddenly lost internet connection
This message was authored by: Doug6
My Sky Q box has suddenly lost internet connection although it shows connection to my broadband. I have reset both my Sky box and my router but this hasn't resolved the issue.  I have checked my broadband connection and all other devices have no problems. Can you please advise?
Re: Sky Q box has suddenly lost internet connection
Hi @Doug6
Have you carried out a Network reset on the Q box.
Hi @Doug6
Avatar for Doug6
I have done both of these but still have no connection.
Avatar for Doug6
I think I confused the reset with the wps button and have now restarted it which has worked. Thanks for your help with this.
This message was authored by: Alan1952
This keeps happening to me on a regular basis every six weeks or so. The Sky Q box says it is connected to my BT Router but there is no internet connection. All other devices in the house are connected fine. The solution here sorts it out but it is right faff entering the SSID. As it is happening frequently is there a total fix or should I contact Sky?
Sky Q 1TB + Mini Box
This message was authored by: Duncan339
My Skq Q box has lost connection with my Sky router. I haver tried the network reset numerous times without success. I have also tried setting the network connection up again by identifying my Sky router and entering the password however it stull days unsuccessful connection. This is strange as the Sky Q box can see my Sky router but cannot connect even though I have entered the correct router password. All my other devices in the house are working fine. Very frustrating.
This message was authored by: Maxdepreciation
Scroll down to Settings but DON'T select it.
Hit 0,0,1 then enter.
Scroll down to Newtork and turn 5GHz off.
Save then unplug your box for a few minutes to help save the settings.
Worked for me.
