This discussion topic has been answered Discussion topic: Sky Q box freezes on exiting BBC Iplayer
Message posted on 25 Sep 2023 03:22 PM
Everytime I exit BBC iplayer my SKYQ box freezes and I have to switch it on and off again at the mains to get it working again. Very annoying.
Message posted on 18 Aug 2024 01:19 PM
@Cryptic1 wrote:
I have some kind of super bug. When I press play on iPlayer for a showing exits and enters a black screen on the sky box. Rebooting sky box doesn't work. I have to reboot sky box AND the TV at the mains to reconnect. Sky, get your head out your @55!
@Cryptic1 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
or
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
Message posted on 26 Sep 2023 10:13 AM
Re: Sky Q box freezes on exiting BBC Iplayer
Hi there, Sharon+Marshall22. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 26 Sep 2023 11:05 AM
Don't do the intuitive press home to exit, you need to use the back button and perform a full exit. That way 8 times out of 10 your box will remain working. This bug is made all the more annoying because of the awful decision to have play from start default action for pressing circle button, so many time i press it to get a program overview and am thrown into iplayer hell
Message posted on 28 Sep 2023 10:22 AM
We are still looking to help you @Sharon+Marshall22 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Message posted on 01 Oct 2023 11:31 AM
Is this a bug then. The Sky box freezes on exit even if I have watched something on iPlayer on purpose.
Message posted on 02 Oct 2023 03:03 PM
Well if software freezes on exit then i would accept it as a bug report from my support department.
Message posted on 11 Nov 2023 11:37 PM
I have the same problem with iPlayer! You watch the program and try to exit and it goes to black screen. VERY annoying as you have to turn the Q box off to clear the issue. There must be a solution to a problem that so many people have.
Message posted on 22 Nov 2023 09:09 PM
I have the same issue. Been like it for years. Iplayer is a pita.
Yet another reset and I didn't even want to watch iplayer.
Message posted on 28 Nov 2023 07:19 PM
I have same issue - it's infuriating as iPlayer comes up as a delayed function of going to a BBC Chanel and pressing select
Message posted on 29 Dec 2023 06:58 PM
I have the same issue. It used to be occasionally but now it's almost every day
Message posted on 29 Dec 2023 07:14 PM
Exactly how are you exiting iPlayer @RussClark
Message posted on 29 Dec 2023 07:16 PM
Usually backup until I get a prompt to exit IPLAYER and I confirm I want to exit.
Message posted on 07 Jan 2024 01:57 PM
Mine too despite going through exit procedure vision dissappear but audio remains on.
Only way to correct is power down & reboot.
Message posted on 07 Jan 2024 06:24 PM
Exactly the same as mine.
Message posted on 08 Jan 2024 01:36 PM
same issue for me too
