Discussion topic: Sky Q box freezes frequently
This message was authored by: MelB23
My Sky Q box freezes every couple of hours and we can only reset it by turning off and on again at the mains socket
Re: Sky Q box freezes frequently
Hi @MelB23
Check that it is not running excessively hot and is well ventilated and not stacked with other devices.
If all is well
