Discussion topic: Sky Q box freezes during playback, remote no longer works. Only solved by powering off and on.
This message was authored by: Robbietherobot
Sky Q box freezes during playback. Remote no longer works and box has to be turned off at the mains to get the system up and running again. Anyone else had this issue and if so any thoughts on how to stop it happening? FYI software is up to date.
Re: Sky Q box freezes during playback, remote no longer works. Only solved by powering off and on.
Hi @Robbietherobot
