Discussion topic: Sky Q box faulty
This message was authored by: Nirvana10
Sky Q box faulty
Our sky Q box keeps freezing and sometimes shows a technical fault message. When changing channels it takes ages to lock onto the channel also when deleting recorded programs it sometimes takes forever. I have tried powering down the box and also full reset but it is still the same until last night we could not get any programs at all. I believe we need a replacement box
Re: Sky Q box faulty
What did you do when you say Full reset @Nirvana10
Avatar for Nirvana10
Went to settings typed in 001 then reset
hi @Nirvana10
Which reset did you do ?
There are three!
I did the top one first a few days ago and it didn't make any difference so I went to try the other resets last night and this morning but the screen is just blue saying technical fault and I can't get it into the reset mode
Hi @Nirvana10
Try the recovery procedure in the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
I have managed to get into the reset mode again and have reset the 2nd button only factory reset if still not working properly
I managed to update the software and to now working how good I do not know but now cannot get two mini boxes to connect to main box. I just tried to tape a program but message came up that there is a problem with the hard disk drive
Still not working properly sky engineer booked
This message was authored by: JUDEJO
Need new sky box
@JUDEJO wrote:
Need new sky box
We're other customers here... Best to call Sky?
...or lets us know what you're issue is and perhaps we can suggest something?
