Discussion topic: Sky Q box disconnecting from internet
This message was authored by: Macca59
Our Sky Q box keeps disconnecting from the internet.  Other appliances are working fine so it is a Sky problem, not internet.  After resetting several times in half an hour I rang the helpline.  Lady there (Emma) took me through various stages, all of which I had done before, but the problem isn't solved.  In fact, the tv won't connect at all now.  I rang back to speak to engineers and hopefully to arrange visit to sort it out as that appears to be what others on this site have had to do but I got cut off.  Sky Help used to be brilliant.  What has happened?  The lady I spoke to also wants me to give her a '10' in the survey.   All well and good, but she didn't solve the problem.  From reading other posts, there is clearly an issue between the Sky Q boxes and the internet connection,.  Come on Sky, help us out here!  Also, the clock is ticking - I will be expecting a refund for the days when we cannot use it.
Avatar for Macca59
Re: Sky Q box disconnecting from internet
Update: managed to get in touch with an engineer and hopefully problem will now be solved.
This message was authored by: Jilly18
My sky box keeps disconnecting continually I have to put in my internet constantly it resets for a bit th. Knocks off.  Mini boxes also affected. continual problem I have updated software.  This is so so annoying my boxes are quite old but getting through to someone is impossible.  Seriously considering cancelling completely.
internet fine with absolutely every other devise in the house.
