Discussion topic: Sky Q apps without satellite signal but have wifi
This message was authored by Drew83 This message was authored by: Drew83
I have recently moved house and not yet informed Sky.  To cut a long story short i connected Sky Q box to non Sky wifi a few weeks ago and was able use apps.  However now it does not work, states i need satellite signal.
Any remedies for this??  Tried refreshing apps and reconnecting wifi.
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Sky Q apps without satellite signal but have wifi
Just one.  Reconnect the dish.
I am just another Sky customer and my views are my own
Drew83
Unfortunately i cannot do this at the moment as where i have moved to is temporary at the moment.  Only an old dish at current property.
This message was authored by oj01 This message was authored by: oj01
A Sky Q box will only work for a little while without a satellite signal. It won't work now until it's connected to the dish.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Staying on Sky+HD
hi @Drew83
Unfortunately as @PandJ2020 says, you will be stuck until you can reconnect it to a suitable LNB (the electronic bit on the dish)
The box needs a periodic authorisation signal (via Satellite)  and although sometimes it allows use for a few days, after that you need the signal for it to work
This message was authored by Mickyt2 This message was authored by: Mickyt2
Many thanks for the info, we lost Satellite signal 3 weeks ago due to scaffolding erected at next door neighbour. However, still able to stream via WiFi to Q box.
Then, after over 3 weeks, it stopped half way through a movie on Netflix. Rebooted but now get the message 'Satellite signal required' when trying to access apps despite Wi-Fi being connected to the box.
Sky engineer appointment in a few days so it's DVD's for us until then.
Thanks for raising this, we lost Satellite signal due to neighbour's scaffolding but was still able to stream via WiFi to Sky Q box.
This was OK for over 3 weeks but now message says we need Satellite signal.e
Bewilderment no more due to the answers to your your post.
This message was authored by DaveP79 This message was authored by: DaveP79
Although apps don't appear to work you can use the voice command or search to find something you know is on an app. It will find it and boot the app. Once in the app you can do usual searching etc
This message was authored by Chodley This message was authored by: Chodley
Oh really? That's very interesting!
