2
This discussion topic has been answered Discussion topic: Sky Q apps. Netflix wont load. Others will but screen freezes. Tried everything recommended
This message was authored by: Dart27
The apps were included with my Sky package and they used to work properly. Recently I have had problems. Netflix rarely loads. Other apps willl  but every few seconds the screen freezes and the red buffer wheel (?) goes round. It is particularly bad on IPlayer. It can happen dozens of times over the course of an hour long programme. The signal strength is 70 and the quality 90, both of which apeear to be ok. I have tried everything recommended. i.e. unplugging the router, unplugging the Sky Q box and doing a Refresh. Nothing works. Please help if you can. Thanks.
Avatar for Dart27
This message was authored by: Dart27 Answer
Re: Sky Q apps. Netflix wont load. Others will but screen freezes. Tried everything recommended
Thank you PandJ2020 for your comment. Your input is apprdciated
That is your satellite signal and nothing to do with network connections/apps.
For the red spinning circle see here: https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
Avatar for Dart27
