Discussion topic: Sky Q and multi room box keep losing WiFi
Message posted on 26 Mar 2025 08:28 AM
The Sky Q box and multi-room box are constantly disconnecting from our Wi-Fi, and it's driving us absolutely crazy. We've confirmed that the Wi-Fi itself isn't dropping, and we're having to reset the boxes daily. They're situated right next to the router, and no other devices are losing connection. We've checked everything – software is up to date. Can't get through on the phone We desperately need help!
Message posted on 26 Mar 2025 12:02 PM
Re: Sky Q and multi room box keep losing WiFi
Hi @A-Wild
Have you followed the procedure below?
if you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
When you get the main Q box connected,
Reboot the
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Message posted on 26 Mar 2025 12:09 PM
If they're right next to the router, use ethernet.
