Discussion topic: Sky Q and mini boxes with third party broadband
Message posted on 02 Nov 2023 06:12 PM
Hi all, I'm currently having third party broadband installed to get the fibre speeds which SkyBroadband can't offer. I've read a load of posts here, but finding conflicting info, so am here to try get ahead of the game before fibre switch-on soon.
I have a Sky Q main box and a few mini boxes.
So my quesion is, what do I need to know? Will everything still work or, as some posts here indicate, do mini boxes not work with third party broadband/wifi?
Thanks!
Message posted on 02 Nov 2023 06:16 PM - last edited: 02 Nov 2023 06:17 PM
Re: Sky Q and mini boxes with third party broadband
Thanks!
hi @JK80
When your wifi is not SKy then the SKY mini boxes do not use your wifi - instead they use a wifi signal generated by the main box
So it is not really a question of won't work just a matter of work differently
How well this will work for each box will depend on how well the wifi generated by the main box & then extended via the minis works.
You can also connect them via ethernet but the main & minis must then be connected together
you are likely to need to reset the network on each of your boxes
Message posted on 02 Nov 2023 06:20 PM
Thanks @nigea99 , that's really helpful.
I think it unlikely the wifi from the main box will extend sufficiently to the mini boxes,
When you say that the main & minis must then be connected together, you just mean all boxes need to be hard wired into the same ethernet?
Message posted on 02 Nov 2023 06:26 PM
By this I mean that a mini must either be connected directly to the main box or both main & mini must be connected to the router (i.e. not just connect a mini to the router and let the main box connect to the router over wifi)
Also I forgot to mention with 3rd party wifi, if connecting the main box to thr router via wifi it only uses 2.4Ghz rather than 5Ghz
Message posted on 02 Nov 2023 06:32 PM
Thanks again @nigea99.
I think I've got it. No doubt something will throw a spanner in the works when the new broadband is running, but at least i've now an idea of what to expect.
Wish me luck!
Cheers.
