Discussion topic: Sky Q and New Samsung TV
Message posted on 08 Jul 2023 10:24 AM
Hi all,
Im hoping someone can help. I've seen some threads on here, but none seemed to fit with the issue we are having.
We have just got a new Samsung tv, UE55CU8500KXXU.
The Sky Q box is connected, and we can navigate through all the menus, however we cannot get a picture from any channel or any recording. We have tried the home, 1,0,8,0 home and the hdmi cable clearly works as we can navigate all menus.
Has anyone got any ideas?
Picture for clarity.
Many Thanks
Message posted on 08 Jul 2023 10:47 AM
Re: Sky Q and New Samsung TV
Hi @rogue1216
The Home 1 0 8 0 Home shortcut is only necessary if you have a completely blank screen.
If you can access the Q menus
Message posted on 08 Jul 2023 11:28 AM
Hi,
Thanks for your quick reply.
That appears to have worked.
Many Thanks
Message posted on 08 Jul 2023 04:29 PM
Hi,
We seem to be having this issue now.
https://helpforum.sky.com/t5/Sky-Q/Fast-forward-not-working-properly/m-p/4336293
Any ideas?
Message posted on 08 Jul 2023 04:32 PM
@rogue1216 wrote:
Hi,
Any ideas?
Hi @rogue1216
Have you tried a Q box reboot
Message posted on 08 Jul 2023 07:15 PM
Hi,
Thanks for your reply again. :-).
Tried the reboot and we are now recieveing an error message at the top of the screen.
"This service is not avaialable because of a problem with your hard drive", this happens whe we press the. "Play, Pause", "Fast Forward" and "Rewind".
Please see image below.
Many Thanks
Message posted on 08 Jul 2023 07:22 PM
Hi @rogue1216
Are you already playing the recording when you get this message?
I ask this because if the recording is playing the hard drive should be fine.
Message posted on 08 Jul 2023 07:30 PM
No, that's trying to pause live tv. Our recordings aren't showing and it's been doing the picture below for the last 45 mins.
Message posted on 08 Jul 2023 07:34 PM
Hi @rogue1216
Certainly looks like an hard drive issue then.
I suspect your only option is carry out a Hard drive reset in the hidden menu.
You will lose all your recordings. Any purchased buy and keep content can be re-downloaded.
Message posted on 08 Jul 2023 07:40 PM
Ok, Thanks for your help.
