Discussion topic: Sky Q and Min Box - Network Connection Fine but saying no internet
Message posted on 29 Aug 2023 10:23 PM
I keep getting an error message to say 'looks like you have no internet' 😤 and the network connection is fine. Ongoing problem since yesterday.
Message posted on 30 Aug 2023 09:01 AM
Re: Sky Q and Min Box - Network Connection Fine but saying no internet
How do you know that the network connection is fine? Is that displayed on the Q or something else?
Message posted on 30 Aug 2023 11:34 AM
Yes, displayed on Sky Q and Wifi is working.
Message posted on 30 Aug 2023 07:16 PM
Have you pulled the power on it. Have had "broadband connection ok" with "no internet connection" before but rarely.
Message posted on 30 Aug 2023 10:58 PM
Having t
Message posted on 30 Aug 2023 10:59 PM
Having the same problem
Message posted on 31 Aug 2023 07:38 AM
I have also just started getting this error, since yesterday. Nothing appears to fix it.
Message posted on 31 Aug 2023 07:58 AM
Hi @DaveB4 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
Message posted on 31 Aug 2023 08:17 AM
Yes, tried that!
