Discussion topic: Sky Q TV screen goes black then comes back on the Sky Q box switches itself to standby mode
This message was authored by: sandra+e
Hi
I'm having problems with TV and not sure whether the TV is at fault or the SKY Q box or the connection between the two. I tried using a new HDMI cable but this didn't solve the problem.  The SKY Q box is still recording programmes. My TV is about 4 years old. I don't want to get a new TV if that is not the problem. Has anyone had anything similar please?  Thank you
Re: Sky Q TV screen goes black then comes back on the Sky Q box switches itself to standby mode
@sandra+e wrote:
Hi
Hi @sandra+e
