Discussion topic: Sky Q TNT Sports shwoing no satellite signal
Message posted on 04 Dec 2025 04:45 PM
I am trying to get my TNT Sports subscription to work on my Sky Q - onlynon that channel it says No Satellite Signal and I cannot find any way to speak to a human being to figure out how to get this resolved hecne resorting to this community as I cannfind no way to get a phone number to call anybody!!!
Message posted on 04 Dec 2025 04:55 PM
Re: Sky Q TNT Sports shwoing no satellite signal
@copelama
If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Message posted on 04 Dec 2025 04:58 PM
Many thanks - I have been round the houses on that link severl times - is there no way to speak to a human being at Sky because it looks like something wrong with the subscription as it also imapcts my Sky Go on TNT Sports?
Message posted on 04 Dec 2025 05:12 PM
@copelama
These are the current methods for contacting Sky. Depending on the reason for making contact some methods will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
