Discussion topic: Sky Q Remote - "Sorry, voice is currently unavailable"
This message was authored by: aynpa
My Dad recently changed his Sky HD+ box to Sky Q in his Care Home environment, one of the attractions was the voice activiation feature of Sky Q given my Dads age (92) and the difficulty he has in using the remote control..
Unfortunately, this has never worked since it was installed less than a month ago.
Checking his TV over the weekend, his Samsung TV does not appear in the list of available Samsung TVs, although when doing the pairing, it does pair up with the first suggested option when doing the volume control test.
Is it possible his unsupported Samsung TV is the reason for the voice activation not working? His Samsung model code is UE43RU7400UXXU.
This message was authored by: Greenfingers001
Re: Sky Q Remote - "Sorry, voice is currently unavailable"
Hi there @aynpa , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Hi @aynpa
It's nothing to do with the TV.
Voice controls relies on Q box internet connection.
Check in Settings - Status and make sure Network connection has a tick.
You could also try resetting the Q box connection.
