Discussion topic: Sky Q - Recordings are failing
Message posted on 12 Feb 2025 02:17 PM
Hello,
Long time Sky user and I am currently on my 2nd Sky Q box.
Virtual assistant is useless at answering and the contact number for Sky Ireland does not connect.
So, at least twice a week I am having the following issues on the Sky Q:
- Either a recording fails with "PowerCut" message - there is no power issues
- "There is a problem viewing this channel" - doesnt make sense as this appears when viewing recordings!
- Other times the screen freezes and the remote does not work. Sky Q needs to be powered off on the way and it goes through the usual "Ready to go in a few minutes" etc. This fixes the issue for a few days until the same thing happens again.
I am getting very frustrated with this. I think a new box is needed, but I cant get through to anyone in Sky to get this arranged.
Any advice appreciated,
Brian
Message posted on 12 Feb 2025 02:20 PM
Re: Sky Q - Recordings are failing
What's happening when you try to contact Sky Ireland? What time of day are you calling as I think their operating hours are not the same as in the UK?
Message posted on 12 Feb 2025 02:21 PM
It is just saying that they cannot complete the call - around 2pm.
It isnt even reaching the menu system
Message posted on 12 Feb 2025 02:24 PM
Are you using the number on this link?
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
