Discussion topic: Sky Q Pause on live programme automatically cancels after minute without pressing play.
This message was authored by: John_S_Rawlins
The live programme is supposed to stay paused for up to an hour until play is pressed.
How can the time-out setting be corrected, or otherwise resolve this?
Re: Sky Q Pause on live programme automatically cancels after minute without pressing play.
@John_S_Rawlins Have you tried rebooting your main Q box ie
also in case you do not realise it will pause for a maximum of 1 hour so if you pause the box for 58 minutes then the next time you pause it will only stay paused for 2 minutes unless you return to live TV first hope that makes sense
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
