2
This discussion topic has been answered Discussion topic: Sky Q, Not recording, Blue screen on play back
This message was authored by: DDD119
Sky Q has suddenly stop recording, and won't play back just has blue screen.
How do you reset the box?
Re: Sky Q, Not recording, Blue screen on play back
Hi @DDD119
First try a simple reboot.
note: some features may take up to 5 minutes to return..
If this doesn't help you can try a Reset Settings in the Q box hidden menu.
Hi @DDD119
Avatar for DDD119
Thanks  @oldfella, sorted
