Discussion topic: Sky Q - No Satellite
Message posted on 09 Mar 2023 12:52 PM
I live within a new development where there is no Sky Dish
my Sky Q box keeps telling me there is no satellite signal but given that I don't have a dish, how can I resolve this?
Message posted on 09 Mar 2023 12:55 PM
Re: Sky Q - No Satellite
Did you arrange a home move through Sky (it would seem you didn't)?
Have the developers put any restrictions on satellite dishes being erected? Some do.
Message posted on 09 Mar 2023 12:56 PM
Yes the Sky Engineer originally installed
Message posted on 09 Mar 2023 12:59 PM
He/She obviously didn't otherwise they'd have installed a dish, set up your system for you and checked that it works.
That's somewhat confusing: Q requires either a local satellite dish or a feed from a communal satellite system. Are you saying it has been working, for live television reception, up to this date?
Message posted on 09 Mar 2023 01:02 PM - last edited: 09 Mar 2023 01:03 PM
Is there cabling from the silver screw-thread connectors on the rear of the main Q box to a wall socket or aperture?
Message posted on 09 Mar 2023 01:03 PM
hi @Martynshac
Some modern developm,ents are fed by a communal System in which case you will need to contact the service providers.
If you are fed by a communal system & have reset the SKy Q box for any reason then you may have to reset the LNB type - if so let us know & we can give details
Message posted on 09 Mar 2023 01:09 PM
Yes it's been working for months. I don't know the technicalities but with new developments they don't install a dish per house but there is a coax type cable from the wall into the box
Message posted on 09 Mar 2023 01:10 PM
Yes there is a coax type cable
Should this be SCR or the other option?
Message posted on 09 Mar 2023 01:12 PM
Yes it should be SCR for a communal feed
