Discussion topic: Sky Q - No Satellite
This message was authored by: Martynshac
I live within a new development where there is no Sky Dish
my Sky Q box keeps telling me there is no satellite signal but given that I don't have a dish, how can I resolve this?
Re: Sky Q - No Satellite
@Martynshac
Did you arrange a home move through Sky (it would seem you didn't)?
Have the developers put any restrictions on satellite dishes being erected? Some do.
Avatar for Martynshac
Yes the Sky Engineer originally installed
@Martynshac
He/She obviously didn't otherwise they'd have installed a dish, set up your system for you and checked that it works.
@Martynshac
That's somewhat confusing: Q requires either a local satellite dish or a feed from a communal satellite system.  Are you saying it has been working, for live television reception, up to this date?
@Martynshac
Is there cabling from the silver screw-thread connectors on the rear of the main Q box to a wall socket or aperture?
hi @Martynshac
Some modern developm,ents are fed by a communal System in which case you will need to contact the service providers.
If you are fed by a communal system & have reset the SKy Q box for any reason then you may have to reset the LNB type - if so let us know & we can give details
Yes it's been working for months. I don't know the technicalities but with new developments they don't install a dish per house but there is a coax type cable from the wall into the box
Yes there is a coax type cable
Should this be SCR or the other option?
Yes it should be SCR for a communal feed
