Discussion topic: Sky Q - No Internet Connection with Virgin Media Broadband
This message was authored by Chodley This message was authored by: Chodley
Re: Sky Q box not receiving internet connection
Few similar threads on this. Virgin broken something again?
Re: Internet connection to sky q box
Virgin Media?
This message was authored by Scoj This message was authored by: Scoj
Yes it is
Few similar threads today. Try changing your DNS on the Sky Q to 1.1.1.1
Be interested to see if that works.
Ok I will do, I unfortunately have had to go to my work now, but I will try that later and respond thanks for the advice
It's possible VM might have sorted it by the time you get home.
This message was authored by KRDrummer This message was authored by: KRDrummer
I wouldn't be in such a rush to change to Virgin TV. I'm on Sky Broadband and Tv and I'm still having the same problem.
This message was authored by ericabercrombie This message was authored by: ericabercrombie
Re: Sky Q - No Internet Connection with Virgin Media Broadband
Before I contact Sky about this issue....does your problem still exist?? i.e does your system say that the router is connected but you have 'no internet'?
This message was authored by OtisRedding This message was authored by: OtisRedding
Can only speak for myself here Eric, I'm not at home to try the above suggestion re: DNS settings.
Just seems odd that no other devices in the home have issues (including a new device added to network yesterday).
Will give it a go later - cheers 🙂
If the problem is with the propagation of DNS entries for sky services, that wouldn't affect anything else.
This post is a bit unusual - do you have some special access to Sky? You joined 9 years ago and only posted twice?
Been like this since yesterday 3pm so that would be ideal lol
Someone in another thread said theirs started working about 7pm last night. Maybe worth rebooting your router and then Q to clear any cached stuff.
I've had Sky for about 25 years or so and my Sky Q box was installed about a year after they came out. This is the first issue I've had with Sky Q and I only discovered it very late last night. So after resetting the Sky box and the Virgin Media router (4 times now) I started googling to see if anyone else had similar issues.......so here we are.
